Wiring-in accessories
Discussion in 'UK Motorcycles' started by Jeremy, May 12, 2006.
  1. Jeremy
    Scraggy Guest
    muddy wrote:
    FFS He was only asking.
    Scraggy, May 13, 2006
    #41
  2. Jeremy
    muddy Guest
    heh
    There's a power commander and a scottoiler hidden under the seat too.
    muddy, May 13, 2006
    #42
  3. Jeremy
    muddy Guest
    Just to clarify, it's 'amateur (ham) radio'.
    muddy, May 13, 2006
    #43
  4. Jeremy
    deadmail Guest
    IMO there's nothing wrong with using scotchlocks as long as:
    1. You cover them thoroughly with self-amalgammating tape to stop water
    getting in.
    2. You don't overload the switched output and use relays as and when
    appropriate; i.e. use the scotchlock to feed the relay coil.
    deadmail, May 13, 2006
    #44
  5. Jeremy
    Dan L Guest
    Ahh, so that's not a big ten four then rubber duck.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, May 13, 2006
    #45
  6. Jeremy
    muddy Guest
    FOC
    muddy, May 13, 2006
    #46
  7. Jeremy
    muddy Guest
    Er, no.
    muddy, May 13, 2006
    #47
  8. Jeremy
    dwb Guest
    Ah hah - you have a power commander? Did you have the bike without it
    first ?
    I'm interested in potentially getting one, but I want to know if they
    actually make any difference - what have you found? On mine there is a
    definite glitch with the FI around 3k RPM, but otherwise it's pretty
    good.
    I'm impressed by how much you've stuck on yours when I consider you've
    had it a fair bit of time less than I've had mine :)
    Have you got other exhausts yet? The most likely things I'll get if I
    keep it are a Power Commander and two (in an ideal world) Akrapovich
    (or similar) cans - should knock about 10% off the weight of the back
    and move the CoG a bit.
    Underseat storage is surprisingly roomy I found if you move the toolkit
    out of the holder and put it back by the rear light.
    dwb, May 13, 2006
    #48
  9. Jeremy
    muddy Guest
    It was difficult to do anything low speed. I'd have to keep the revs up
    and slip the clutch otherwise it would jerk about and then stall. Not
    good when you are filtering or riding on a fire road.
    I had an idea of what I wanted to do when I bought the bike.
    I'm not planning to change the cans. I need to keep it quiet due to
    where I live. There's 2 cunts that live down the road from me that have
    harleys with open exhausts. I want to keep a low profile. I don't think
    5 or 10 HP change is worth the cost either. The fucker will go faster
    than I need now.
    Yep, the lube tube, PC and the tool kit.
    muddy, May 13, 2006
    #49
  10. Jeremy
    Scraggy Guest
    Yes, I rather thought that was the case...
    #50
  11. Jeremy
    dwb Guest
    Very interesting - as that's exactly what I have with mine - low speed
    manouvers can be scary in that the bike is hard to control and very
    jerky. Exactly as you say this shows itself most when filtering, or for
    me, doing right turns (so a left turn for you) - particularly worrying
    when it's wet.
    I'd originally put this down (as per my previous posts on this) as the
    gearing not being quite right - but if it's the FI....did you find the
    PC improves this, straight out the box as it were?
    If so, then I'm definitely going to get one as that is one thing I
    could say really DOES bother me and is hard to ride round (slipping the
    clutch excessively has it's own perils IMO).
    Re the cans - I'd be looking at road legal ones - I want the weight
    saving, not an increase in noise.
    dwb, May 14, 2006
    #51
  12. Jeremy
    muddy Guest
    You need the proper map for your bike, but once that's loaded it'll run
    fine.
    Ah, right. I didn't know anyone made road legal cans for it. Let me know
    what you find as I'd be interested too.
    muddy, May 14, 2006
    #52
  13. Jeremy
    muddy Guest
    I thought with the V-Strom it was for emission reasons. The SV-1000 and
    the TL use basically the same engine and I have never heard of low speed
    engine problems with either of them.
    muddy, May 14, 2006
    #53
  14. Jeremy
    Jeremy Guest
    OK well this is what we have - which of course works in my limited
    testing (about 50 miles or this afternoon). I used a scotchlock
    connector (well bound with insultaing tape) to tap into the tail light
    circuit (+) - this then runs into a 5A fuse and then to the cigarette
    lighter socket. The -ve from here is connected directly to the battery
    -ve.
    Into the cigarette lighter socket I plugged in the PDA's transformer and
    routed its power lead up to the headstock. A few cable ties (allowing
    sufficient slack) and, though I say so myself, a bloody neat job.
    Now here's the question to you and WUN - having ignored the advice above
    (as I didn't know what kind of relay to get nor how it would need t be
    wired in and I was too imaptient to not get something working) - what is
    it that a relay safeguards against in this kind of situation? Is it a
    problem related to the different currents drawn on the same circuit? I
    mean it appears to work perfectly at the moment... seriously if there is
    a real risk of doing some kind of damage then I'll rewire it this week,
    but am looking for some guidance here (please).
    cheers
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, May 14, 2006
    #54
  15. Jeremy
    deadmail Guest
    Two issues here:
    1. You used insulating tape; that won't keep the moisture out and there
    is a risk that water will find its way into the cable and corrode the
    wire over time.
    2. By not using a relay you run a risk of overloading the circuit to the
    rear light; carry spare fuses (for the original rear light circuit) in
    case they blow.
    deadmail, May 14, 2006
    #55
  16. Jeremy wrote
    Sort of. In this type of application (typical in automotive
    environments) a relay is used as a low power switch to switch a
    (separate) high current circuit. Just like the little flimsy button
    under your right thumb acts to provide a tiny current to a relay which
    switches on a larger current and makes your starter motor spin.
    steve auvache, May 14, 2006
    #56
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Jeremy
    Well since you're ignoring the advice, there's not a whole hell of a lot
    of point in repeating it, is there? ;^)
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer
    Wicked Uncle Nigel, May 14, 2006
    #57
  18. Jeremy
    Jeremy Guest
    Awww come on.... if I understand what it safeguards and how to wire
    it... then I can follow the advice. And no, I'm not begging (much).
    jeremy
    Jeremy, May 15, 2006
    #58
  19. Jeremy
    Jeremy Guest
    So does the relay have a couple of inputs and one output? Its purpose
    then would be to for example sit between the battery +ve and the device
    you want to power. Also feeding into it would be a wire from the (in
    this example) rear light circuit (or perhaps the relay sits in-line in
    the chosen low current circuit). When the lights are switched on,
    current flows to the relay which then opens the circuit from the battery
    to the device?
    I guess the wiring is probably more complicated than that but have I got
    the gist of it?
    jeremy
    #59
  20. Jeremy
    Jeremy Guest
    Ah - the reference to "self-amalgammating tape" - I filtered out
    everything except the last word as that is what I have in the garage.
    Ok this is because that circuit might be designed to carry 3A say and if
    I go and double that then I'm buying trouble? Then I now follow why
    taking the positive straight from the battery was suggested.
    jeremy
    #60
