wiring!!!
Discussion in 'UK Motorcycles' started by beno, Jun 1, 2006.
  1. beno
    beno Guest
    having trouble with my cg125
    it starts and runs fine---without the battery connected, or any wires
    connected, even the ignition switch
    have to stall it to stop it
    what do i need to connect up so i've got basic stopping and starting
    working using the ignition switch????
    my old ignition switch which was drilled out coz of a lost key has 5
    wires coming out of it, 1 green 1 red 2 black and 1 black/white
    the new switch i got only has 4 wires , red , green, black, black/white
    any ideas???
    beno, Jun 1, 2006
  2. <Makes Sign Of Holy Pushrods>
    The Older Gentleman, Jun 1, 2006
  3. beno
    mb Guest
    beno wrote:
    Use fewer[1] question marks.
    [1] Hah!
    mb, Jun 1, 2006
  4. beno
    Cut the blue wire.
    platypus, Jun 1, 2006
  5. can you multi meter them out
    Steve Robinson, Jun 1, 2006
  6. beno
    beno Guest
    I've got a haynes manual on the way... really need the wiring
    diagram....
    wish I knew more about electrics, i get totally confused when talking
    about earthing things and checking fuses...lol
    beno, Jun 1, 2006
  7. The convention on this group is to bottom post , if you ignore the
    convention some of the other posters will bite you
    steve
  8. The Older Gentleman wrote
    There are some things brother that are beyond simple faith. It is
    possible that this time even the gods will be unable to help.
    steve auvache, Jun 1, 2006
  9. Don't panic. If you can get a scan of the Haynes wiring diagram
    to me, and have a multimeter (ohmmeter, continuity tester) to test the new
    switch, we should be able to walk it through together.
    Maybe...
    Oh, and please don't top-post here!
    Dr Ivan D. Reid, Jun 2, 2006
  10. He's got it. I do believe he's got it!
