WTF have I DONE?
Discussion in 'UK Motorcycles' started by Pip, Sep 30, 2008.
  1. Pip
    Dropped a grenade in XP, it seems. Now, I've had this before, but I
    can't recall how to get out of it. It's to do with typing: I can type
    in native Windows apps (Word, notepad) as normal, but Agent will only
    recognise alphanumerics (no return, backspace, delete etc) and I can't
    enter text into, for example, the google search box and it certainly
    won't let me enter a url into Firefox. I can get text into IE's
    address bar, but no spacebar or other functions.
    Also, Windows Desktop Search keeps opening, unbidden.
    I've removed Agent pro tem (as the first program that showed a fault)
    and I've performed two System Restores, back a day and a week
    respectively.
    AVG checks the whole machine every day and reports nothing and I'm
    up-to-date with Spybot and Ad-Aware checks: again, nothing to report.
    If anybody can understand my problem (well, this one, at least) and
    offer a solution, it'll be virtual beers all round. FFS, save me the
    agony of rebuilding my five-year-old XP Pro installation.
    Pip, Sep 30, 2008
  2. Pip
    Simon Wilson Guest
    Indeed. Desktop search hotkey appears to be windows-shift-f by default.
    Simon Wilson, Sep 30, 2008
  3. Pip
    You've tried a different keyboard presumably - simple things first etc.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Sep 30, 2008
  4. Angle Grinder.
    Whinging Courier, Sep 30, 2008
  5. Pip
    Yup. No difference: still playing the daft lad.
    Pip, Sep 30, 2008
  6. Pip
    Thought of that, but no joy.
    I just pulled a whole new trick - out of nowhere, up popped the start
    menu and an Agent dialog box asking if I wanted to mark all messages
    read - this accompanied by a rapidly repeated note, damned thing
    sounded like a doorbell. Got rid of that and an open Excel
    spreadsheet started doorbelling, accompanied by two simultaneous lines
    of letters (asasasasasasasasas ... ) writing themselves across the
    sheet in rows 1 and 7. Stopped that (after boggling a bit) by hitting
    the spacebar and then closing (and not saving changes) the
    spreadsheet.
    I'm fucked, I think it's haunted.
    Pip, Sep 30, 2008
  7. Pip
    have you got one of those doohickeys that convert PS/2 to USB or vice
    versa?
    maybe your {whichever one you are using} channel is fucked. Try the other
    one.
    I managed to introduce a random "fault" to my 3 year old box when fitting a
    new mouse. It came with a PS/2 adapter so I saw an opportunity to free up a
    USB slot. It seems the bios was monitoring that PS/2 channel for a wake-up
    call. I became a little pissed off with the machine waking up again after I
    had gone to bed, until the penny dropped.
    wessie, Sep 30, 2008
  8. Pip
    Catman Guest
    Power down. Unplug. Have a cuppa
    Plug it in *without* keyboard.
    Same issue?
    www.cuore-sportivo.co.uk
    Catman, Sep 30, 2008
  9. Pip
    Tosspot Guest
    "Keyboard not detected. Press F1 to continue."
    Tosspot, Sep 30, 2008
  10. Pip
    The keyboard is a straightforward straight-into-the-USB type and I've
    tried changing slots, to no avail. I've also tried reloading the
    (Windows) drivers, to no effect. Now I've plugged in an old PS/2
    keyboard straight into the appropriate connector and that doesn't work
    at all - the NumLock light doesn't illuminate, even.
    Oddities: the original USB keyboard seemed to have all the function
    keys disabled: not just the Fx keys, but anything that does stuff -
    but the letter keys worked. Then the letter keys disabled themselves
    except when they wanted to stick on and I'd get a never-ending row of
    alternating asasasas .... It doesn't want to do anything at all now,
    neither does the PS/2 board.
    It must be a software problem, that won't sort with a System Restore -
    but where do I look? Nothing is showing as a problem anywhere.
    Pip, Oct 2, 2008
  11. Pip
    Alex Ferrier Guest
    That or your I/O controller's up the swanee. Are all your other
    USB devices working correctly?
    Alex Ferrier, Oct 2, 2008
  12. Pip
    Pete Fisher Guest
    Could it be the keyboard controller on the motherboard ?
    | Pete Fisher at Home: |
    Pete Fisher, Oct 2, 2008
  13. Pip
    Pete Fisher Guest
    As you suggest, checking if the PS/2 port is disabled would be a good
    starting point. I was just thinking what it might be if the port wasn't
    found to be disabled.
    Driver issues, don't you just love them. The PC equivalent of "shit in
    the carbs".
  14. Pip
    It appears not. A couple of reboots later and a bit of fiddling
    around and I have full functionality restored. The PC just didn't
    recognise the connection to start with, I assume - but it's "installed
    new hardware" now and all is well.
    Saitek Eclipse. It wasn't just the function keys, it was all keys
    that perform a function (rather than producing a letter, iyswim) such
    as spacebar, return, delete or backspace.
    I assume it was well-intentioned and therefore not ridiculous - but
    I'm running XP Pro because it does what I need it to do and I know
    there'll be problems with Vista - let alone Linuxing the thing.
    Cheers.
    Pip, Oct 2, 2008
  15. Pip
    Strangely, yes, they are. Looks like a keyboard issue after all.
    Pip, Oct 2, 2008
  16. Pip
    Keyboard controller in the keyboard, perhaps. Could be that the
    sprayed coffee has finally got to it ;-)
    Pip, Oct 2, 2008
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    Thing about a Linux Live CD / DVD is that you can boot the machine from
    it without touching the Windows install on the HDD.
    Fucking handy for eliminating hardware issues (amongst other stuff), is
    that.
    Worth downloading and burning an image "just in case". Jim's was a good
    call.
    Wicked Uncle Nigel, Oct 2, 2008
  18. Pip
    Without using the keyboard *at all*? This also precluded doing
    anything with the BIOS, of course.
    I'm not violently against *nix per se, but I don't want to try to run
    it as a full-on OS as all the required man pages reads and configs
    would bring out my inner geek and thus remove me further from ever
    getting a life.
    I'll grab one. Recs?
    Pip, Oct 2, 2008
  19. Pip
    Don't do it - you'll only end up with an 's' key that only generates
    '$', & you've had enough grief with fucked keyboard$ a$ it i$.
    Krusty
    Krusty, Oct 2, 2008
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    Yep. Set the machine up to boot from the CD / DVD first, then the HDD.
    You need to do that before the KB's fucked, of course... ;^)
    Christ no, this is an "emergencies only" thing. No anorak required. In
    this case, boot it up and try to log on. If the keyboard is still doing
    weird stuff, it's hardware, right?
    I'm out of date[1]. Seventeen evangelists will be along directly to
    confuse the **** out of you.
    I think my DVD is Linux Mint, but it's buried deep in a huge pile over
    ----> there. Let me know if you need me to check.
    [1] No change there, then.
