XJ 600 Ticking From Engine
Discussion in 'Motorcycle Technical Discussion' started by Bolthole, Dec 15, 2006.
  1. Bolthole
    Bolthole Guest
    This is a post for information only, really...
    I have and XJ 600, pre diversion, which for a long time ticked quite
    severely from one side of the head.
    After much searching groups and general head-scratching, I discovered
    that the ticking was caused by a bad seal where the exhaust downpipes
    join the cylinder head. Basically the problem just got worse until it
    was kind of obvious, from the sound of the exhaust, that gas was
    leaking out in a big way!
    I took the exhaust off, thoroughly cleaned out the recesses where the
    collapsable ring gaskets went, and indeed found that the pipe in
    question actually had the remains of an old gasket underneath the
    current gasket.
    I replaced all the old gaskets, using the copper type rings, also using
    a smear of exhaust repair putty, just to be sure and carefully
    re-fitted the exhaust. This cured the problem and seemed also to
    restore a little lost power, and certainly made the engine idle a lot
    better. It sounded a lot nicer too...
    One additional symptom that's worth noting was that the inside of the
    downpipe on the affected cylinder was light grey in colour (the others
    were black and a bit sooty!) seeming to indicate that the leak was
    causing this cylinder to run a lot leaner and hence hotter....
    Oh well, not really inviting any further comment, but I hope this post
    saves someone a bit of time...
