Just bought son1 an off-roader, £210 worth of XL 125 [1], nothing drastically wrong with it apart from what appears to be worn front wheel bearings, possible head bearings and, as the seller says, a tapping noise from the head, which I assume would be the tappets ;) Most work appears done and it appears oil-tight, though we never really got it hot. However the kickstart appears to slip when kicking it over, but returns to same position as before so I suspect it's the kickstart shaft internally somewhere missing a tooth perhaps. Is this a known problem with them? Any other known major faults with them? I think, bicbw, that this is the same engine as the CG, is that right? Where would be a good place for parts, info etc for this bike ? [1] ebay 120049396763 Cheers.
