Xmas comes early, it lives and TOG takes the biscuit.
Discussion in 'UK Motorcycles' started by Pete Fisher, Oct 15, 2009.
  1. Pete Fisher
    Pete Fisher Guest
    So I took the plunge and ordered an ultrasonic cleaner off Ebay from
    'China'. Not only did it arrive within a week (in a box from a warehouse
    in the south of England), but it works.
    Stripped down the CB250 Nighthawk carb again. Filled the tank with a
    litre of Clean Machine parts cleaner and two of warm water. Put the jets
    and other small items in the natty round fine mesh basket and the float
    bowl and body in the larger mesh basket along side. Twenty minutes at 30
    degrees.
    Shinier than very shiny things they became. Squirts of carb cleaner in
    to orifices had very promising results. Put it all back together and
    pressed the button. Sounded better straight away. Even without the air
    cleaner back up it will rev freely with part choke. Won't rev it too
    hard until I have changed the oil.
    So a biscuit to TOG - yow wos roit!
    Do I need to adjust/check the cam chain tensioner, and if so how?
    So Fisher's Fastidious Carb Cleaning service is open for business. Note,
    however that it will only take one smallish carb, so no four cylinder
    banks I'm afraid. It will however, take the carb/FI bodies off any of my
    fleet plus any number of other smallish components. Chuffed I am.
    Here is the beast in an unnatural habitat (it is aimed at the dentistry
    market).
    http://www.flickr.com/photos/21676903@N06/4014669774/
    | Pete Fisher at Home: |
    | Voxan Roadster [ SPACE ! ] Yamaha WR250Z |
  2. Pete Fisher
    TMack Guest
    What are the internal dimensions? I have been thinking about getting one
    myself but I am not sure what size to go for.
    TMack, Oct 15, 2009
  3. Told yer ;-)
    Got the auction details for the machine you ordered, btw? I might get
    one.
    IIRC, they're fully automatic on those things. Ask a Honda dealer. They
    *might* be like the CD200 benly: semi automatic. If so, there'll be a
    protruding thingy and a nut on the back of the block, and all you do is
    undo the nut and re-tighten.
    <Checks online parts fiche>
    Looks fully auto to me.
    The Older Gentleman, Oct 15, 2009
  4. Pete Fisher
    *perk*
    I assume it would take a Morini Dell'Orto?
    Timo Geusch, Oct 15, 2009
  5. Pete Fisher
    Pete Fisher Guest
    Oh indeed so and I shall be treating the old spare 25mm jobs I have.
    Also will take the carbs off the GFR an YZs. I hope never to have to
    fiddle with the Voxan Magnetti Marelli throttle bodies. One of the
    Nordwet Keihin smooth bores would have gone in, perhaps both still
    linked but not fully submerged. The Teikei would have been a squeeze,
    but Simon has got that now ;-)
  6. Pete Fisher
    frag Guest
    took a blunt brush and painted...
    I see there are two power output types, both 5L.
    Cheapo ones are 120W ultrasonic module, expensive ones are more than double
    at 300W for only £30 or so more.
    frag, Oct 15, 2009
  7. Pete Fisher
    Pete Fisher Guest
    I went for a 300w unit, but also one that clearly stated UK voltage. It
    came with a continental two pin power lead, but as it is a standard
    'kettle' type connection at the box I had an old PC monitor lead lying
    about.
    I'm not sure if the lid needs to be on other than keeping in the heat
    (goes up to 80 degrees but I only went to 30). With it off larger things
    could be turned after a bath IYSWIM.
  8. Pete Fisher
    Eddie Guest
    .... or, stick a screwdriver in the earth pin of the socket to open the
    shutter, and bung the two-pin power connector in the now-open holes.
    Eddie, Oct 15, 2009
  9. Pete Fisher
    Eddie Guest
    <Safety nazi mode>
    But, but "water and electricity don't mix!"[/QUOTE]
    As long as you're not trying to clean the mains lead, you should be okay.
    Eddie, Oct 15, 2009
  10. Pete Fisher
    Hmm. Fancy doing at least the rear one off my 3 1/2?
  11. Pete Fisher
    Pete Fisher Guest
    So long as you do the stripping down and re-assembly. Not keen on
    borking other folk's threads and fiddly bits, though Dellorto VHBs are
    very simple in comparison with the complicated little Keihins. I'd try
    not to lose any pingfuckits. In fact you probably only need to have the
    body ultrasonically cleaned on one of those as the jets are pretty
    simple to check. I suppose I could offer an exchange service at least on
    the body. Are you still on alloy intake elbows?
    Otherwise, you would have to be quick unless you can wait until after
    half term. Then there is the postal strike to consider, or were you
    thinking UR, possibly via a Stafford Show attendee?
  12. Pete Fisher
    Simon Wilson Guest
    Wassat and where do you get it from then? I tried all sorts of
    concoctions and ended up with just water in mine in the end.
    I hope yours last longer than the Chinese ones I had. I burnt through
    two of them before I ended up buying a rather more substantial unit.
    Simon Wilson, Oct 15, 2009
  13. Pete Fisher
    Pete Fisher Guest
    Ah, memory burp, forget the 'Clean Machine'. It's one of the Autoglym
    range available from Halfords. I've also got a can of Gunk 'Green' in
    reserve.
    You probably give them more intensive use than I ever will.
    Pete Fisher, Oct 16, 2009
  14. Pete Fisher
    Ben Guest
    Hmm, I could do with something like that for bicycle parts.
    Got a link?
    Ben, Oct 16, 2009
  15. Pete Fisher
    Simon Wilson Guest
    Simon Wilson, Oct 16, 2009
  16. Pete Fisher
    Simon Wilson Guest
    Try again.
    I didn't use them that much. They all have timers IIRC. I had a set of
    carbs from a SOHC 750/4 that I cooked quite a few times in my efforts to
    get it to run better. (It's still not 100%). According to when I looked
    into it lots of people had problems with the transducers if they weren't
    careful with the duty cycle. At least the (ebay) supplier I used gave me
    my money back.
  17. Pete Fisher
    Pete Fisher Guest
    Don't think I could get a bank of four carbs in mine at the same time.
    Thanks for the heads up on the possible problems. I must resist cleaning
    every small oily part in sight for the sake of it.
  18. Pete Fisher
    Simon Wilson Guest
    I didn't get the whole bank in assembled - they were stripped down as
    small as they would go.
    The bike's still not 100% (or the last time I tried it, it wasn't). It
    ran not bad, but rich. Mpg was awful. Some of those internal passageways
    seem next to impossible to clean out. I've been wondering about trying
    to remove all the little brass plugs from them (maybe by getting them
    really hot).
  19. Pete Fisher
    frag Guest
    Look, will you stop it already?
    I've got absolutely no reason to own one, all I'd do with it would be to
    chuck various things in there and see what happened (PCB, would it take the
    solder off and unsolder everything? Egg, would it break down the shell? My
    fingers, would it clean under my fingernails *really really* well?)
    frag, Oct 17, 2009
  20. Pete Fisher
    eamo Guest
    He speaketh the truth. In a previous life, i used to flog these. Had a
    variety at home *for testing*
    No end of stuff went in, and proportionally interesting results came
    out.
    YKIMS
    eamo, Oct 17, 2009
