XP Install USB Keyboard not recognised
Discussion in 'UK Motorcycles' started by sweller, Dec 20, 2009.
  1. sweller
    I'm trying to clean install Windows XP on a Dell Inspiron desktop and
    have a bit of a problem.
    The keyboard works to change the boot settings in the BIOS (the mouse
    lights up too), allows me to "Press key to boot from CD..." the mouse
    stays lit whilst Windows setup gets all its drivers loaded then when it
    gets to the "Enter to install, R to repair" etc. the keyboard doesn't
    work and the mouse laser goes out.
    I've checked all usb ports and no joy and there is no PS2 socket, the
    keyboard isn't locked (it doesn't even light up).
    Obviously I can't install windows unless I can get it recognise the enter
    key...
    The machine already has Ubuntu and I'm overwriting it so "Install Linux",
    "Anglegrinder" and "TIUTA" can all join O:SYFF.
    Any ideas?
  2. Is there a bios setting to enable legacy usb ?
    Brownz \(Mobile\), Dec 20, 2009
  3. sweller
    Nothing "legacy" in the BIOS, USB is enabled.
  4. Weird.... there's normally a bios switch that allows enumeration of usb in
    non legacy os's, might be worth trying a couple of other keyboards, and I've
    got a USB -> PS/2 - KEYB converter I can lend you to try out which might
    work.
  5. sweller
    I've got one of those but there's no PS2 input on the Dell box.
    Unless you mean it allows a PS2 keyboard to be attached to a USB socket -
    the problem is the USB sockets seem to die as the mouse goes out too.
  6. The latter, we use them in production where we have a mix of operating
    systems at various stages of installation. As long as you have a PS/2
    Keyboard & mouse still knocking around somewhere.
  7. sweller
    I may have fixed it.
    After a bit of poking about with Google it turns out that an XP Install
    +SP2 works. The genuine copy I have is XP only, I have a "backup" copy
    of XP+SP2 which now seems to be working (I've managed to progress to
    format the HDD) keyboard reacts properly.
    I just hope the genuine XP Pro key I have works with the XP Pro "backup".
  8. sweller
    ginge Guest
    If you've access to another machine you could slipstream SP3 onto the
    legit CD you have... which would solve the problem and also mean
    you're not stuck with a dodgy cd.
    Here's how..
    http://www.helpwithwindows.com/WindowsXP/Slipstreaming_Windows_XP_Service_Pack_3.html
    ginge, Dec 20, 2009
