XS650 Update
Discussion in 'Classic Motorcycles' started by The Older Gentleman, Nov 5, 2005.
  1. Well, I've run around on it for a week or so now, and the inevitable
    little niggles have surfaced and been dealt with.
    The most serious was the leak from the end of the camshaft, mentioned
    before. One new oil seal, a gasket and an O-ring (cost under a tenner0,
    and 45 minutes' work (two-thirds of which was scraping off the old
    gasket) sorted that.
    There was another, smaller weep from the camchain tensioner cover - a
    bloody great thing that screws onto the tensioner locknut. You need a
    22mm spanner to undo the cover, and a 25-26mm (no idea, because I
    haven't got one that big and so used an adjustable) to undo the locknut.
    Fasteners on XS650s tend to be *big*.
    The weep was due to someone having tried to undo the locknut with a
    hammer or something. They'd put a slight burr on the edge, which
    interfered with the proper seating of the cover. Oh, and the cover's
    O-ring was old and hardened as well. The took 10 minutes to sort -
    carefully flat down the burr, and dig out a replacement O-ring from the
    box in the garage.
    Slightly more worrying was the way it died on my way home, on the
    darkened A21 last night. Eek. No engine, but at least I still had
    lights. I flicked the kill switch on and off and was rewarded with a
    nice backfire and it picked up again.
    I thought I'd accidentally hit the killswitch, but 20 miles later it did
    it again. again, flicking the killswitch on and off sorted it.
    OK, so we have a dicky killswitch. I carefully stripped it down (lots of
    pingfuckits) and yeah, the copper contacts were dirty, so cleaner and a
    rag were brought into play. And then the little circlip that holds the
    bloody switch together did the classic pinkfuckit as I was re-assembling
    the bastard.
    No way could I find it. The air turned blue. As it does.
    Never, ever, ever throw anything away. I reckoned the little circlip
    that holds ignition points together would be the right size, and I've
    got some old points sets knocking around. You never know when you might
    want the tiny little screws and clips. And yay! A perfect match.
    I've treated it to a full service. You don't even have to remove the
    fuel tank to set the valves, which is brilliant.
    It cruises happily at 70-75. These US models are slightly lower geared
    than the roadsters, and so it would redline at about 105-110, I reckon
    (calculated because the speedo is an 85mph maximum one). An 18-tooth
    gearbox sprocket would raise the gearing a tad. A brand new genuine
    Yamaha one went on Ebay for an astonishing £30 this week - I was going
    to bid on it, but gave up in amazement. A new pattern sprocket is only
    £15, ffs.
    But gearing it up would lose that fabulous flexibility. You can run it
    down to 25-30 in top, and open the throttle and it just snaps away.
    Utterly brilliant. And the fuel consumption isn't bad anyway - 51mpg on
    the first tankful, and 55mpg on the second.
    I might experiment with a different sprocket, but it's not a priority.
    The front brake is crap. One single-piston caliper does not stop 430lbs
    of ShiteOldYamaha and *cough* lbs of rider. There's a lug for a second
    caliper, and I've got a spare disc, so I might look out for an SR500
    caliper, which does the trick. Or the left-hand caliper from an XS750,
    which is the same unit.
    It's incredibly smooth and sweet. The smoothest XS650 I've owned.
    whether this is because it's got the US engine with the 20mm shorter
    conrods, I don't know. Obviously, every single component is
    rubber-mounted, and obviosuly, if you're used to a Jap four it feels
    like a road drill, but still, compared to the hammering of a Brit twin,
    it's extraordinary.
    Me Happy Bunny.
  2. The Older Gentleman
    Bruce Porter Guest
    On Sat, 05 Nov 2005 12:19:17 +0000, The Older Gentleman wrote:
    Bugger, stuck in Leeds until Ged knows when........... hope you don't sell
    it before I can get down for a go :-(
    Bruce
    "The internet is a huge and diverse community and
    not every one is friendly"
    http://www.ytc1.co.uk
    Bruce Porter, Nov 6, 2005
  3. I ain't selling it. I sold the GPz550 instead.
    Mind you, that hasn't stopped Hog trying to tempt me....
    The Older Gentleman, Nov 6, 2005
  4. The Older Gentleman
    'Hog Guest
    message
    Well the lovely Irene has a hankering for a little CB1 sitting in
    Kernahans here. It's like a swiss watch, I believe they even have gear
    driven cams. 14000rpm red line and 55bhp. I haven't found a bad review
    about them, everyone seems to rave on. The only thing that concerns me
    is spares availability??
    I'm thinking that the Bandit 400, which was imported to the UK, might
    not be such a nice bike but would be easier maintained and re-sold.
    SO. Final Offer. £1200 and a night on your wine cellar, if collected
    within a week or so. It would become mine after she moved on and up
    y'see (1)
    It's past time that you 'fluenced young Rich BTW!
    (1) tried the R100RS on for size last night. With a Hagon 1" lower
    shock (needs new anyway), forks dropped an inch, a Sure Foot sidestand
    and a seat job it could work. Those extra narrow bars must have been
    made for a woman anyway.
    'Hog
    'Hog, Nov 7, 2005
  5. The Older Gentleman
    TOG Guest
    You utter bugger. No - but I'll give you first refusal when/if I come
    to sell it. I've just bought a pair of NOS oil filters on Fleabay, from
    Germany. The XS650 uses washable mesh filters, one on the right-hand
    side of the engine, like an old Honda twin, and one in the sump.
    They're not supposed to be replaced, but washed in petrol, and the one
    in the sump has a reputation for holing *really* easily.
    TOG, Nov 7, 2005
  6. The Older Gentleman
    'Hog Guest
    Hmm I wonder where the breaking point is for this one ;o)
    'Hog
    'Hog, Nov 7, 2005
