So one of the fork seals was leaking and I thought I'd fix that plus fit gaitors. Both forks (on a 30 month old bike) were very hard to pull apart (well one not done yet). The root cause (apart from needing to have a tool to hold the damper rod) was the amount of corrosion around the fastners was unbelievable. Every single fastner's gone in dry without any use of grease or similar in exposed areas. (e.g. around the bolt head in the bottom of the forks to keep the salt-water out.) Grr. Guess I'm not out on the bike tomorrow.
