Yam XJ600 Diversion HELP!
Discussion in 'UK Motorcycles' started by Cooky, Aug 1, 2006.
  1. Cooky
    Cooky Guest
    Hi
    Got a problem with the above. After a run, lots of engine oil under the
    bike. Found its coming from inside the air-filter box under the tank
    and spilling all over the engine. The air-filter is saturated as is the
    inside of the box. I dont know why this is happening. Any help would be
    appreciated!
    Cheers!
    Cooky, Aug 1, 2006
  2. Cooky
    The rings/bores are fucked. Or you've dropped it recently & haven't
    mentioned it.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Aug 1, 2006
  3. Common problem with the Diversion - mine did it.
    It required a modification to the breather arrangement. I got the
    dealer to do the mod and I think it cost me about £50 and it's been fine
    ever since.
    Steve Fitzgerald, Aug 1, 2006
  4. Cooky
    WavyDavy Guest
    Isn't there the possibility that there's too much oil in it and that the
    excess is being pumped out of the breather into the airbox...?
    Not that I ever did that with the Porsche about 3 years ago or anything...
    Honest.... Ish... It had a Wacky Races style smokescreen behind it until
    we managed to drain the excess litre and a half (filled it up on a slight
    incline, didn't I?) but once the air filter was cleaned up it ran fine
    again.
    That said the OP hasn't made any mention of plumes of white smoke when it
    was running, which I'd expect if the airbox is full of oil.
    WavyDavy, Aug 1, 2006
  5. Cooky
    Well I'd say it's a fairly safe bet that the oil in the airbox is
    coming up the breather, but whether that's due to over-filling, crank
    pressure or a drop is anyone's guess. Over-filling seems unlikely
    though as only a totally clueless twat would do something like that.
    Perhaps his mirrors aren't as good as Lozzo's.
    Krusty
    Krusty, Aug 1, 2006
  6. Cooky
    UKRM at it's (rare) best. An immediate concise technical solution.
    Hog, Aug 1, 2006
  7. Cooky
    Guesswork?!? That was a highly in-depth & technical[1] analysis of the
    problem I'll have you know. Bloody "guesswork" indeed.
    [1] & wrong, probably.
    Krusty
    Krusty, Aug 1, 2006
  8. Cooky
    Woops, how did that one get out of the box <snares the little bugger>
    Hog, Aug 2, 2006
  9. Cooky
    BORG Guest
    Try here
    http://groups.msn.com/YamahaDiversions
    www.ratrodz.co.uk
    XJ900 Trike GS850 Trike
    [Rot 13 it]
    Some people are like slinkys....
    no real use but it makes you smile when they fall down stairs!
    BORG, Aug 3, 2006
