yamaha RD350 4LO
Discussion in 'Motorcycle Technical Discussion' started by KM, Nov 23, 2004.
  1. KM
    KM Guest
    I am facing some problem on my 4LO tt i was unable to troubleshoot:
    on idle, the bike is fine.
    both exhaust smokes and is hot.
    when throttle opening, left exhuast has no smoke and the bike stall.
    checked carburettion, all's fine.
    check ignition all fine too.
    check reeds all fine
    no leakage of coolant...
    background:
    bike running on premix at 33:1.
    still facing same prob...
    pls help..
    rgds
    km
    owd
    sg
    KM, Nov 23, 2004
  2. Crankshaft seals????
    The Older Gentleman, Nov 23, 2004
  3. KM
    SAMMMMM Guest
    did you check to see that the needles are both ok and are both properly
    moving with the slide?
    switch coils.
    are both slides moving?
    do you mean that the engine stalls as you rev it up out of gear?
    (i forget, does this one have constant velocity carbs?)
    if so, the left diaphragm is not operating and the left slide is not
    lifting.
    good luck, sammm
    SAMMMMM, Nov 23, 2004
  4. KM
    Bill Smith Guest
    Do both slides rise when you turn the throttle? Left side cable could
    be off. Check to make sure both slides move together.
    Are your float levels correct? A marginally low float level in the
    left carb could provide plenty of gas for idle but not enough to make
    any power. Is your fuel filter partially clogged? Low fuel flow can
    cause this.
    A weak ignition coil could cause this. Both plugs will fire when you
    look at them during troubleshooting, and at idle, but under load, a
    weak coil wouldn't fire the plug. Swap the coils and see if the
    problem changes to the right side.
    When I assemble an RD, I pressure check it. This requires plugging the
    intake and exhaust tracts (both sides, because the center seal on the
    crank is only a labyrinth seal) and pressurizing to about 10 psi. If
    it leaks down at more than about 1 psi per minute, you have a problem.
    Things I've seen on RDs (None of these things are your problem)
    Owner in a hurry, and installs left slide in right carb, and vice
    versa. You can do this if you put the slides in backwards. Runs really
    rich.
    Pistons installed backwards with ring gaps in exhaust port.
    New owner fills transmission case with two-stroke oil thinking that's
    where it's supposed to go. When I see the motor, it's seized, oil tank
    empty, transmission filled solid.
    Bill Smith, Nov 23, 2004
  5. KM
    KM Guest
    you mean slides for both carbs are different?
    km
    owd
    KM, Nov 30, 2004
