ying ying ying, screee, clunk, silence
Discussion in 'Classic Motorcycles' started by mike. buckley, Sep 27, 2004.
  1. Feck
  2. mike. buckley
    Seized, eh? Don't worry, TOG's prolly got oversize pistons and rings
    for it, and gaskets.
    Champ, Sep 27, 2004
  3. Kickstart is locked solid, but you can turn the crank 180 degrees by
    hand using the flywheel (very tight) - both pots have compression, can
    still change gear. Bit baffled to be honest, I'm guessing left hand side
    of the crank, but as we've got the builders in, I'm not really inclined
    to strip the engine down while they're wheeling barrow loads of sand
    through the garage....
  4. mike. buckley
    JB Guest
    Piston ring picked up in a port? My old KX500 did this when the ring rotated
    due to the end-gap locating pin disappearing somewhere.
    PS: Want to sell it as a going concern guvnor?
    JB
    JB, Sep 27, 2004
  5. mike. buckley
    Bob Scott Guest
    Know that feeling well...
    I've got a YPVS lump of some flavour (F1?) in the shed which has, AFAIK,
    a sound bottom end (well, crank seals will have died in storage) if you
    know what bits are needed.
    Never did get around to sticking it in the LC & have sold things like
    the igniter box...
    Bob Scott, Sep 27, 2004
  6. Yeah I think you sold it to me.....
    I'm weeks away from stripping it down, but I'll give you a shout if I
    need anything. I've got a spare gearbox, but if the cranks gone I'll
    have to grab a recon.
  7. mike. buckley
    TOG Guest
    *Snort*
    Been there, done that, with a Power-Valve. And a GT185, come to think
    of it.
    if you need some OS rings, I've got air-cooled RD350 ones at +1.00mm
    and I'm 99% certain they fit the power-valve, although Lozzo will be
    along shortly to confirm or deny. Free to you, guv.
    TOG, Sep 27, 2004
  8. mike. buckley
    Keelworm Guest
    Piston Broke??? Incidentally, so am I.
    PG
    Keelworm, Sep 27, 2004
  9. LC?
    Austin Shackles, Sep 27, 2004
  10. mike. buckley
    says...
    The genuine RD400 rings will fit genuine Yamaha RD350LC and Powervalve
    pistons, but you can't use RD400 pistons in a Powervalve engine. The
    ring gaps are spaced just so they catch in the main inlet port at the
    rear of the Powervalve's barrel. Just as well I checked before fitting
    the RD400 pistons into my old Powervalve really.
    They are currently in use as paperweights in my office.
    Lozzo, Sep 27, 2004
  11. mike. buckley
    JB says...
    Sounds about right. Broken ring is lodging in the port. Had it happen to
    an RD250 once. You're looking at a rebore at the very least.
    Lozzo, Sep 27, 2004
  12. Cheers. OK, Pigwanker, I've got RD400 rings as well.
    The Older Gentleman, Sep 27, 2004
