you get what you pay for...
Discussion in 'Motorcycle Technical Discussion' started by Gene Cash, Apr 5, 2007.
  1. Gene Cash
    Gene Cash Guest
    Well, you do get what you pay for.
    I have an '02 SV-650 with nearly 50,000 miles on it, and I bought a new
    DL-650. The DL really highlighted just how bad the SV clutch had gotten.
    So I got one of those cheap EBC clutch plate kits. That was a big
    mistake. It was a little better, but the friction zone was still rather
    marginal. I checked the actuator, filed off the notches in the clutch
    basket, sanded the gum off the steels, checked the cable and cable
    routing. Still rather poor.
    I finally stumped for the OEM plates since I had to buy a special bolt
    for my rear brake. I figured there was no sense paying $8 shipping for
    an $8 bolt and I'd wanted the plates for a while.
    Anyway, after soaking them in oil for two days, I did a straight swap.
    Oh my god, the difference! It does feel like a new clutch now.
    You can see why stock is $70 vs. $20 for EBC. The OEM plates are thinner
    with thicker friction material vs the EBC thick plates with almost
    painted-on friction material. The OEM plates are better machined vs the
    EBC worn-die stampings, and the fingers are actually the proper width to
    fit in the basket. The OEM friction material doesn't chip off if you
    look at it funny like the EBC stuff does.
    EBC brake pads are crap, I don't know why I thought their clutch plates
    might be worthwhile.
    The SV is now fun to ride again.
    -gc
  2. Gene Cash
    Gene Cash Guest
    Really? Like what?
    I know I have to order OEM Suzuki brake pads online because the local
    dealer only wants to push EBC.
    -gc
  3. Gene Cash
    Wudsracer Guest
    The "KG Clutch Factory" spring and discs kits are available for your
    bike from PU. Look here:
    http://street.parts-unlimited.com/17/328/4093056 .
    As a m/c dealer, I was told that KG supplies the OEM friction discs
    for many of the Japanese brands.
    I like the DunlopPad friction discs, but they are not cheap.
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, Apr 5, 2007
  4. Gene Cash
    Wudsracer Guest
    It's very hard to beat the wear life of the OEM Nissin brake pads.
    They last for a long long time. I am just now changing the rear pads
    for the first time on my GasGas.
    (20 months of regular use in all sorts of conditions. BlackJack,
    SERA, & TSCEC enduros.
    AHSCS hare scrambles.
    Lots of trail riding: http://members.cox.net/jejb/Wudi9/wudi9.html.)
    The only aftermarket pads (that I am aware of) that give anywhere
    near the wear life of the OEM pads, are the DunlopPad (DP) brake pads.
    Look here: http://street.parts-unlimited.com/5/160/3997237
    The DP brake pads (also sold as "Moose") are not as abrasive to the
    rotors as the EBC pads, and wear three times longer.
    These are the only pads that I use on my GasGas, since the Nissin pads
    (through GasGas) are around $70 per set.
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
  5. Gene Cash
    Gene Cash Guest
    Not unless I really insist and raise a stink. It's changed since the new
    manangement, not that it was terrific before, but at least it was decent.
    -gc
    Gene Cash, Apr 6, 2007
  6. Gene Cash
    Gene Cash Guest
    "KG Clutch Factory springs are approximately 20% stronger than OEM" so
    I'll skip on the springs.
    Plus at $60 it's only $10 cheaper than stock. And the $85 "kevlar
    series" is even more expensive than stock.
    I wonder why they don't recommend the "pro" plates for the DL-650?
    -gc
  7. Gene Cash
    Gene Cash Guest
    They don't out-and-out refuse, they just make it really difficult.
    Last time I ordered parts from them, it was January, and it was
    September before I got them. Thank $DIETY for ronayers.com!
    -gc
  8. Gene Cash
    oldgeezer Guest
    Ah.. the good old days...
    We did that for bikes too. Usually there also were two or three hollow
    rivets
    to keep the material in place.
    It was almost white, very soft material. Brand name was Ferodo.
    We filed the leading and trailing ends with a coarse file.
    I must have inhaled a lot of asbestos.
    And the friction material for a wet clutch was cork.
    I still know how to get those oversized pieces
    into smaller holes.
    Rob.
    Rob.
    oldgeezer, Apr 6, 2007
