You know you're bored with life when...
Discussion in 'UK Motorcycles' started by BGN, May 4, 2006.
  1. BGN
    BGN Guest
    You get given a laptop to 'fix' and can't get it to charge with the
    Merkin adapter supplied when plugged into a one amp shaver plug but
    instead of changing the fuse to a higher rated one you drill a hole in
    the plug you just stick a screwdriver where the fuse should be
    instead, and then stick it in the wall.
    Works perfectly, BTW. It may be a bit of a hazard to everyone around
    it, however.
    BGN, May 4, 2006
  2. BGN
    Beav Guest
    Is this an attempt to get blown to bits.
    When are you moving to Bert?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 4, 2006
