YTC Nomination
Discussion in 'UK Motorcycles' started by JackH, Nov 5, 2008.
  1. JackH
    JackH Guest
    Given I have a bit of spare time on my hands, I've been giving the VFR a
    really thorough going over this week, doing all the jobs one normally
    neglects to do etc.
    You know, things like stripping down the rear suspension linkage and
    cleaning and regreasing all the bearings etc.
    So far, with a degree of success I've:
    * Acquired a 2k model stainless collector box and downpipes, decatted it (1)
    then re-finished the pipe in a nice heat resistant black and fitted a rather
    spiffing Staintune high level stainless can with removable 'DB Killer' bung.
    * Fitted a Power Commander 2 and set the mapping up for the aforementioned
    pipe.
    * Removed the exhaust studs which snapped as I removed the old collector
    box.
    * Changed the rear shock for a longer, low mileage EMC one, plus of course
    the work on the linkage as detailed above.
    * Plug, oil and filter change, together with lobbing out the standard air
    filter and replaced it with a K & N flat panel.
    * Realised the head races were knocking, so dropped them down, noted they
    were a bit dry but not worn so cleaned them and repacked them with grease.
    All of the above had gone quite well, so when it came to the ineffective
    back brake which I decided to tackle today, I was expecting this to go
    reasonably smoothly despite the fact it has, due to the linked brakes, a
    total of *five* bleed nipples you need to bleed in a set order if you expect
    it to work again.
    Anyway, rear wheel off, caliper off, no problem at all.
    Getting the pistons to pop out was a bit of a challenge, even in the face of
    me doing all this in a bonafide workshop with on tap compressed airlines,
    the lot, but no matter, they came out eventually.
    Cleaned all caliper itself off in an industrial steam cleaner and polished
    up the pistons on an wire wheel, then fitted new piston seals (2) and
    reassembled the caliper, jobs a good un.
    Caliper placed on the rear disc but facing the other way as per both the
    factory and Haynes workshop manuals, check.
    Cap removed from fluid reservoir, and commence bleeding... which seems to be
    going ok initially, albeit I'm not very impressed with the fluid flow rate
    and starting to wonder if the rear brake has another issue which was why it
    didn't work too well in the first place.
    And then I'm finding no flow at all from the third of the five bleed
    nipples... not even a hissing of air when the nipple is loosened whilst the
    rest of the system is under pressure, and the fluid, having happily dropped
    initially, isn't dropping any more.
    So I come to the conclusion it must be a defective 'PCV Valve' (3), and go
    home to fetch both this and the spare rear pedal cylinder I've also got,
    just in case.
    Get back to the workshop and decide what would actually would be better
    would be to drill a hole in the cap of the spare reservoir, and then use
    this orifice to pressurise the system slightly when bleeding it, in the hope
    that the fluid being forced down the lines would then displace the air that
    *must* be trapped in the system and stopping the fluid from flowing through.
    And it's at this point I removed the cap from the spare reservoir, and
    noticed that, when I removed it, not only did the cap come away in my hand,
    but so did a big rubber membrane with white plastic collar, cunningly
    fashioned from the same colour plastic as the reservoir itself.
    Turns out I'd been topping up the upper side of said rubber membrane with
    fluid, and the level was 'going down' on the initial attempts at bleeding,
    due to the level below it dropping and sucking it down inside.
    I are, given the time spent scratching my head on this one... a TC. :)
    Anyway, hopefully, given it's a basic 'bolt it all back together' session
    tomorrow, I shouldn't encounter any other 'difficulties' of this nature!
    (1) My bike is a 98 model, ergo it's not supposed to have a cat anyway
    before anyone starts muttering about me ruining the environment - the
    fuelling is already set up for a non-cat system and running cats in a system
    like this will end up destroying them anyway.
    (2) If anyone from Honda UK is reading this, £21 for six, what are
    essentially squared off o-rings no bigger than an inch diameter, is taking
    the fecking piss even by your standards.
    (3) This is the valve which sits midway on the bike and regulates the split
    of fluid flow between the front and rear brakes when you apply the rear.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    03 VW Passat TDI Sport
    89 Vauxhall Nova 1.3 Pearl
    JackH, Nov 5, 2008
  2. JackH
    JackH Guest
    Google URL?
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 5, 2008
  3. JackH
    JB Guest
    <snip: all good stuff>
    *Top* work Sir!
    #should have gone to Specsavers...#
    JB
    JB, Nov 5, 2008
  4. JackH
    JackH Guest
    Hahaha... I'll take a picture of it tomorrow and then maybe you'll see why
    it took me so long to work out. :)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 5, 2008
  5. JackH
    JB Guest
    No need. BTDT, although it took me about 10mins of very confused
    looking/prodding/poking to _finally_ suss it out. Why they didn't make the
    damn membrane in fluo yellow or something is beyond me.
    <"Aaaah Toyo San. How we **** with Round Eye's brain today?"
    <"No probrem. We make all mating parts real close tolerance
    and...<snigger>...all same fucking colour!" "Gajin monkey him on beer most
    of time so not spot difference for aaaaaages. We **** him good this time">
    <Aaaah. Reckon Round Eye go postal and say many rude words about Honda when
    he find out....">
    JB
    JB, Nov 5, 2008
  6. JackH
    wessie, Nov 5, 2008
  7. JackH
    Lozzo, Nov 5, 2008
  8. JackH
    Eddie Guest
    Ha!
    Try buying a set of OEM seals for a ZX-xR...
    Eddie, Nov 5, 2008
  9. JackH
    JackH Guest
    Go on then... remind me why it was such a good thing not to have kept the
    ZX9R I had recently...
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 6, 2008
  10. JackH
    Eddie Guest
    Eddie, Nov 6, 2008
  11. JackH
    JackH Guest
    JackH, Nov 6, 2008
  12. JackH
    JackH Guest
    Good idea.
    Yes, that's about the size of what happened this afternoon. ;-)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 6, 2008
  13. JackH
    It's far easier to source some 4 pots from a Gixer 600 or TLS and fit
    those instead. I have heard some Nissin calipers go straight on, but
    haven't checked for myself. Nissin calipers are anodised where the
    seals sit, so don't corrode at all.
    Lozzo, Nov 6, 2008
