Z13 Fuel Filter Snag
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Apr 27, 2006.
  1. I have this odd snag with the Z13, and any ideas would be welcome.
    The filter sits upright, with fuel delivered from the tank into the top,
    with the outlet at the bottom into the pump.
    The problem is that it looks like it's sucking air in to the filter, and
    I can't work out why. It's bad enough to disrupt flow to the engine at
    higher throttle openings and cause a slight mis-fire.
    I've had problems in the past with the tap being blocked with shite, but
    that looks OK and fuel flows well enough from the tap if I disconnect
    the filter end. All connections are tight AFAICS.
    Is there a bleeding procedure for these things? The Kawasaki Book Of
    Half-truths has no mention of such.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer
  2. Obvious reply - is the filter upside-down? Some of them have arrows
    indicating the flow direction, in case you didn't know.
    Si
    Mungo \Two Sheds\ Toadfoot, Apr 27, 2006
  3. In uk.rec.motorcycles, Mungo "Two Sheds" Toadfoot belched forth and
    ejected the following:
    Wot 'e said plus "they all do that", at least the two I've got on
    different bikes do it and they're both fast as ****.
    Whinging Courier, Apr 27, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, "Mungo \"Two
    I've checked, the in says "IN" and the out says "OUT".
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    <dashes out to garage>
    <returns[1]>
    Erm...
    The round black things are at the bottom and the 'KAWASAKI' badges are
    the right way up.
    I think it's OK. Is there anything else I should check?
    [1] Having considered booting up one of[2] the workshop PCs, and decided
    against.
    [2] Is that sad?
  6. Wicked Uncle Nigel
    Gyp Guest
    Which way up is WUN?
    Don't worry, as of tonight, there are 4 PCs up and running at chez Gyp,
    but it's OK, there's only one Linux box. Actually if we're counting
    Linux boxes I guess the Linux broadband router/firewall counts so that's
    5. Does the fact that I check eBay on my mobile make it 6..?
    Gyp, Apr 27, 2006
  7. Wicked Uncle Nigel
    You could try measuring the flow-rate, say by measuring how long it takes to
    drain a litre of fuel, with and without the filter. If there's a
    significant difference, you could try a bigger filter, or two smaller
    filters in parallel.
    platypus, Apr 27, 2006
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    Ummm... Insufficient data. Please ask another question.
    Got to go see a doctor in the morning.
    Don't do doctors, don't do mornings. Bad combination.
    Not sure. Which one has the naked pictures of T? An IP address is
    probably enough.
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Ooh, sums.
    Sums is 'ard. Should I get a man in?
  10. Wicked Uncle Nigel
    IIRC the Bling-6 has fool-injection. I'm wondering if there's another
    filter integral to the system. Perhaps on one of the lower decks, near the
    engine room?
    platypus, Apr 28, 2006
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Not according to the book of half-truths. I'll have the crew conduct a
    search, just in case.
    Wicked Uncle Nigel, Apr 28, 2006
  12. Wicked Uncle Nigel
    mb Guest
    Wicked Uncle Nigel wrote:
    How will you get him in the filter?
    mb, Apr 28, 2006
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, mb
    <pats food processor>
    It gets odder.
    Fuel flow from the tank is fine, as is the filter, but there's an
    unhealthy head of air stays in the filter that gets sucked down into the
    pump.
    I think I'll try priming the filter to fill it, then connecting the
    input hose.
    Fucktifino what's going on.
    Wicked Uncle Nigel, Apr 29, 2006
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, Mark Olson
    Hmm...
    I've been blaming the WFO misfire on this. Maybe it's something else?
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Mark Olson
    That second one sounds like a plan. I'll give it a whirl.
    It was a new filter fairly recently, thobut.
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    I can see large air bubbles being sucked into the outlet at higher
    throttle settings. Seems to me that they must hit the injectors at some
    point, no?
    The mis-fire feels *exactly* like the one that set in when the fuel tank
    tap was blocked, and it behaves the same way too (back off a bit, then
    gas it and it's OK).
    I'll do that.
