Zippo fuel
Discussion in 'UK Motorcycles' started by Whinging Courier, Oct 3, 2005.
  1. Is there a sensible alternative[1] until I can get to a shop that sells
    it tomorrow?
    Is meths ok? I don't want to use unleaded.
    [1] There's always the toaster
  2. In uk.rec.motorcycles, Bear amazed us all with this pearl of wisdom:
    Toaster it is then.
    Ta.
  3. Whinging Courier
    R obbo Guest
    Rub 2 Boy Scouts together?
    Robbo
    Trophy 1200 1998
    BotaFOF #19. E.O.S.M 2001/2002/2003/2004/2005
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
    R obbo, Oct 3, 2005
  4. Lighter fluid, afair, is naptha. UL petrol will burn but fairly smokily.
    Never tried meths in a Zippo, but if it doesn't actually blow up in your
    hand, then what's the harm.
    Grimly Curmudgeon, Oct 3, 2005
  5. Whinging Courier brought next idea :
    What, for drinking?
    I wouldn't know.
    Harry Bloomfield, Oct 3, 2005
  6. Whinging Courier
    Kevin Stone Guest
    When I used to smoke, I always use to dip mine in my tank on a piece of
    string I specially made [1].
    [1] about 12 years ago now [2]
    [2] before unleaded?
    Kevin Stone, Oct 3, 2005
  7. Whinging Courier
    I've used meths in a Zippo before - it takes a good spark to light it,
    but doesn't taint too much and there's no lasting side-effects to the
    lighter. Other common flammables aren't so good - unleaded tastes
    particularly bad and smokes like a bastard. Don't even consider
    thinners, OK?
    Rum and black works quite well and yields a fruity, sweet taste to yer
    tab but it turns your wadding purple - which fades to pink after a few
    fills of the right stuff. Whisky isn't bad ...
    Pip, Oct 4, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    And unleash the pooper-scoopers of war?
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Oct 4, 2005
  9. Whinging Courier
    Bear says...
    I've used old aftershave, it stinks.
    Lozzo, Oct 4, 2005
  10. Whinging Courier
    I've still got the pink-wadded lighter in question. Exhibit One.
    When you're pissed and your lighter dies, it was common practice
    amongst the banger/stock car racing fraternity that I was then
    associating with to refill it with anything flammable that came to
    hand. If it was out of a glass belonging to the pisshead on the end
    of the bar who had just leaked off, so much the better in the general
    hilarity stakes - especially if you used it to light his next fag.
    In my defence, I've never used single malt to fill a Zippo - but I
    know a man who has. Bushmills, otoh ...
    Pip, Oct 4, 2005
  11. Whinging Courier
    zymurgy Guest
    Always the burny stuff of choice when it came to burning brake fluid
    out of riveted brake shoes.
    Goes up like a bastard ;-)
    Cheers
    Paul.
    zymurgy, Oct 4, 2005
  12. In uk.rec.motorcycles, Rope amazed us all with this pearl of wisdom:
    I stopped smoking herbal fags at almost exactly the same time I tried
    them ;)
    Whinging Courier, Oct 4, 2005
  13. Whinging Courier
    prawn Guest
    *cough* I've use petrol in the past. Wire coat hangers are your friend.
    prawn, Oct 4, 2005
  14. In uk.rec.motorcycles, prawn amazed us all with this pearl of wisdom:
    WEll I saved a lot of messing about and bought some of the real mackoy.
  15. Whinging Courier
    Owen Guest
    What are the thoughts on sambucca or vodka?
    Owen, Oct 4, 2005
  16. Whinging Courier
    Owen Guest
    Take 1 bottle of vodka, 1 vanilla pod (split down the middle) 1 or 2
    big spoons of brown sugar (adjust according to taste)... Try not to
    touch for 2 weeks... :)
    Owen, Oct 5, 2005
