I have a 1985 Kawasaki Eliminator that is running hot. After 15 - 20 minutes of stop and go riding the temp warning light comes on. I have flushed the cooling system, replaced the radiator cap assembly and thermostat and used DEX-COOL in the system. I have also pulled the water pump cover to ensure the pump impellers are not gummed up but to no avail it continue to run hot. The radiator fins seem to all be in order and the fan/relays turn on and off. I do not have any coolant leaks and it does not appear that there are any vacume leaks in the system. Any ideas? Any help would be appreciated!
