ZRX1100 woes
Discussion in 'UK Motorcycles' started by AW, May 8, 2007.
  1. AW
    AW Guest
    Little brother's '97 ZRX1100. He's had it from new, uses it rarely
    and panders to it so it's only done 12000 miles and is pristine. It's
    just had the 12k service done by a small firm in London, close to
    Tower Bridge, but the next day started running on three. He took it
    back and, of course, it ran perfectly. Few days on, back on three
    again, so he hoiked the plugs out to have a look and found one very
    sooty. He changed the plugs but it was still not right so went back
    again but got a fairly frosty response.
    A few days on and it's back on 3 again, and now also dribbling fuel
    from the overflow pipe and emitting blue smoke from the exhaust like a
    two wheeled Red Arrow. Though I reckon he should go back and create a
    fuss, he says he's not letting them anywhere near his bike again. I
    suspect it's that old favourite, Shit In The Carb, but anyone else
    have any suggestions?
    AW, May 8, 2007
  2. AW
    AW Guest
    Well, yes, that's likely a major part of the problem. But not an
    immediate solution.
    AW, May 8, 2007
  3. AW
    AW Guest
    That's basically my thoughts. It's been serviced religiously by the
    original dealer - but they're down on the S Coast miles from where he
    lives which is probably why he used this outfit where he could drop it
    on the way to work, get the tube in and then pick it up on the way
    home.
    Any other possibilities for the cause than SITC?
    AW, May 8, 2007
  4. AW
    AW Guest
    Jap & German Motorcycles. I could find very little about the, good or
    bad, before he went there.
    AW, May 8, 2007
  5. Name?
    The Older Gentleman, May 8, 2007
  6. AW
    Eiron Guest
    No. It's a sticky float valve, probably due to crap in the pipe.
    A thrash at WFO often helps. If not, dismantle, clean, replace.
    Don't leave the petrol tap on 'prime' while the engine isn't running
    or you might fill one cylinder with petrol and get hydraulic lock
    when you try to start it.
    Eiron, May 8, 2007
  7. AW
    AW Guest
    CV Carbs. Sticky slide, or blokcet jet, most likely, I reckon.
    AW, May 8, 2007
  8. AW
    AW Guest
    Eiron wrote:
    Great stuff, thanks..
    AW, May 8, 2007
  9. AW
    Rings a faint bell, that place - I think they're advertising as some
    kind of BMW specialist doing both used bike sales and servicing.
    Judging by the few bikes I saw advertised and the money they were asking
    I've mostly given them a wide berth; nor do I know of any other BMW
    rider using that place for servicing...
    Timo Geusch, May 8, 2007
  10. AW
    AW Guest
    I won't be recommending them after the way they dealt with brother.
    BTW, I'll get in touch about the Norton soon but off to NY tomorrow
    for a week.
    AW, May 8, 2007
  11. AW
    AW says...
    That's the outfit in Druid Street, in the arches?
    Lozzo
    Suzuki GSX-R750L trackbike (Shite with added shite bits)
    Yamaha SR250 Cheasy-Rider (undergoing a transformation)
    I ride way too fast to worry about cholestorol.
    Lozzo, May 9, 2007
  12. AW
    SD Guest
    Yep.
    | ___ Salad Dodger
    |_\_____/_| ..88203../..24080.../..31896.
    SD, May 9, 2007
  13. AW
    Not a surprise, that.
    OK, no worries. I'm off to see my mum for the last week in May but other
    than that I should have the time on a weekend.
    Timo Geusch, May 9, 2007
  14. AW
    AW Guest
    Have you used them? Close enough to me, but I hadn't heard of them
    before this.
    BTW lunchtime beer, when I get back?
    AW, May 9, 2007
  15. AW
    SD Guest
    No. A colleague with a Rockster got them to install a set of rear
    pads.
    Me, use a bike mending shop, when I could spend weeks without end in
    my own garage? The very idea.
    Oh, aye.
    | ___ Salad Dodger
    SD, May 9, 2007
