ZX9R-C1 No oil presure ?
Discussion in 'UK Motorcycles' started by eric the brave, Dec 3, 2005.
  1. OK, so I've just fitted another gearbox because mine was jumping out of
    4th when engine breaking. I've put the limp back in the frame connected up
    the wires ready to check that the oil pressure light goes out. Remove the
    spark plugs, filled up with oil to the half way mark and pressed the
    button. After 5 secs the oil light was still on DOH :(
    I checked to see if oil was circulating by removing the oil filter. No
    squirty squirty when I press the starter. I first though that the oil pick
    up pipe had fallen out, but no it was intact. I then thought the oil pump
    wasn't turning, I removed the water pump to view the spindle. It turn
    when I press the button. I'm at a loss what to do next. I've removed
    the oils pressure switch expecting to see oil squirting out of that. But
    alas no. I guess it's not sucking up the oil from the sump. I would have
    expected to see the oil level drop quick as the oil circulated.
    Any suggestions?
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, eric the brave
    Did you use Hermetite or anything similar when you put the lump back
    together?
    Sure you haven't left a spanner / rag in the sump? ;^)
    Other than that, I'd be really tempted to stick a squirt of oil into the
    cams and down the bores and fire the sucker up for a few seconds to see
    if that "cures" the problem.
    Wicked Uncle Nigel, Dec 3, 2005
  3. That's what I thought. I've had the oil pump off, nothing in there. Then
    it's a straight pipe to the oil filter. Which I removed. It's like it's
    got an air block or something. very strange. The sump strainer pipe is a
    good tight fit as well. Perhaps I need to fill it right up to the top of
    the window. I need some more cheap oil; to test it first. The only other
    thing I can think of is a pin or something missing from the drive gear on
    the other side where the pump shaft is run off the clutch I think. But
    that was never taken off.
    Much thinking is going on...
  4. That was crap because I tightened the bolt on the end of the water pump
    impeller and the shaft didn't turn. So It's connected up OK.
  5. Hmm... it might be one of those oil pumps that has to be lightly packed
    with vaseline on refitting. Unusual but it happens. You occasionally get
    a pump that just won't self-prime after a rebuild, but is fine
    subsequently.
    Grimly Curmudgeon, Dec 3, 2005
  6. Trouble is, it's the bit before the "subsequently" that is painful.....
    The Older Gentleman, Dec 4, 2005
  7. Spot on Mr Bling. Well sort of, I filled the thing up to the top of the
    sight glass last night and went to bed. This morning after 10 secs on the
    starter with no plugs in the pressure light went out. I guess I was just
    being over cautious.
    eric the brave, Dec 4, 2005
  8. Or as the case may be the pump is fine but the rest is FUBAR...
  9. eric the brave
    Or, as the case may be: the switch is fucked and the rest is fine.
    Pip, Dec 4, 2005
  10. Switch is fine. The system works at about 26 PSI and the switch worked.
    It's the half a newspaper up the oil pipe that was worrying me. But all
    was well in the end. All I need to do now is fit the full Akropovik(sp)
    back on add the newly kitted carbs[1], and see if the kit makes a
    difference.
    [1] Factory tuning kit.
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, Beav
    Not after three weeks it won't, no.
    Wicked Uncle Nigel, Dec 21, 2005
