ZX9R E1 default suspension settings?
Discussion in 'UK Motorcycles' started by frag, Apr 6, 2007.
  1. frag
    frag Guest
    Anyone know what they are?
    IHJFGI and found Bears reference to the PB article, but not the article
    itself.
    Found a few default settings, but for the Bs or Cs or unspecified model.
    Also has anyone got that PB setup guide? A photocopy/scan would be much
    appreciated.
    frag, Apr 6, 2007
  2. Two secs. I'll have a look. Do you want a PDF workshop manual. I should
    have one somewhere. Probably C1 though.
    eric the brave, Apr 6, 2007
  3. frag
    Lifted from Dr Molly's site:
    http://www.sportsbike.org/suspension/pictures/sus1w.htm
    HTH, I have the setup we used for Elly's bike here too if required.
    Pip, Apr 6, 2007
  4. frag
    And in hot pursuit of the Bad Form award:
    The book says (stock settings):
    Front preload 13mm from top of adjuster/5 lines showing
    Front rebound (fork top) 10 clicks out
    Front compression (by spindle) 10 clicks out
    Rear rebound (by shock linkage) 10 clicks out
    Rear compression (by brake reservoir) 10 clicks out
    Set the static sag first.
    On Elly's bike we ended up with 4/4/6/6/10
    A fast road setting is 4/4/4/3/10 with a bit more rear preload.
    Have fun ;-)
    Pip, Apr 6, 2007
  5. Bad form and all that, but I appear to have deleted it all. DOH.
  6. frag
    Molly Guest
    Check your static sag before you use the settings on my site.
    Molly, Apr 6, 2007
  7. frag
    frag Guest
    eric the brave banged the rocks together and they said :
    Doh indeed, no worries, EBay will have one :)
    frag, Apr 6, 2007
  8. frag
    frag Guest
    Pip banged the rocks together and they said :
    Cheers mate. Having a look at Mollys site I think i'm a bit of a Keith
    and then some.
    I'll return them to stock, see what its like, and then probably adjust
    the front rebound/compression for my svelt figure.
    frag, Apr 6, 2007
  9. frag
    frag Guest
    Molly banged the rocks together and they said :
    Will do.
    On your site there are stock and PB settings for the E1/C2, and only
    Keith settings for the C1/C2, correct?
    Just want to be certain cause I know some browsers make a right cock up
    of tables, shifting things round to where they shouldn't be.
    One thing of note is that I will be replacing the 190 rear with a 180
    profile when the time comes, as I know doing that on old E1 vastly
    improved the turn in. (but its the same physical height so should make
    no difference to ride height)
    frag, Apr 6, 2007
  10. frag
    frag Guest
    Hmm, those are different to the default settings on Mollys site.
    frag, Apr 6, 2007
  11. frag
    Alan Guest
    The owners manual for my bike disagrees too. It says :-
    Front spring preload adjuster 13mm from top of adjuster.
    rebound damping force adjuster 8th click from fully turned in.
    compression damping force adjuster 8th click from fully turned in.
    Rear - rebound 8th click from fully turned in - compression 10th click
    If you still need a scan of the PB article I can do you one.
    Alan, Apr 6, 2007
  12. Found it. Only for c1-c2 though.
    http://zapik.com/tmp/zx-9r-98-99x.zip
  13. frag
    ginge Guest
    It's not, you know.. it's slightly bigger.
    190/50 sidewall height = 50% of 190mm = 95mm
    180/55 sidewall height = 55% of 180mm = 99mm
    So the bike on 180/55's rides 4mm higher at the rear, which sharpens the
    steering angle, improving turn in..
    ginge, Apr 6, 2007
  14. frag
    ginge Guest
    Do you, Molly and Elly all weigh the same then?
    I suspect you'll all need very different settings.
    ginge, Apr 6, 2007
  15. frag
    frag Guest
    frag, Apr 6, 2007
  16. frag
    frag Guest
    ginge banged the rocks together and they said :
    Saving me playing around shimming the rear.
    Nice!
    frag, Apr 6, 2007
  17. frag
    frag Guest
    Well of course, but its always a good idea to set the bike back to
    factory settings and then adjust from there.
    It also helps me make more accurate guesstimates as I can mentally plot
    a "body weight to settings" graph and extrapolate it to my weight. And
    then find out I should set everything to negative clicks.
    It also helps because I can find out that the previous owner had the
    front rebound set two clicks different on one side.
    Du with a side helping of 'oh.
    frag, Apr 6, 2007
  18. All depends on if you are running a 5.5" or 6" rim. 180's are supposed
    to go on 5.5" rim. The ST runs a 180 on the 6" rim from factory though.
  19. frag
    frag Guest
    Alan banged the rocks together and they said :
    If you can that'd be great Alan.
    Email address I use to post here is valid.
    Cheers!
    frag, Apr 6, 2007
  20. frag
    ginge Guest
    IIRC they changed the tyre on the E1, but kept the same geometry, which
    slowed things down a bit and spoilt the bike. Most people in the know
    just changed back to the original set-up.
    Probably one of the reasons why they've gone up to a 190/55 on the new
    10R actually, to get back to the older turn in characteristics but keep
    a wider contact patch. But, erm, Wibble-flip-dibble-doo.. as they say.
    ginge, Apr 6, 2007
