ZX9R E1 default suspension settings?
Discussion in 'UK Motorcycles' started by frag, Apr 6, 2007.
  1. frag
    ginge says...
    I'd very much doubt that you, Frag, Bonners, Champ or any other road
    rider would notice a 4mm profile difference in a road tyre while they
    were riding. You might notice the difference in turn in, but not the
    ride height difference.
    Lozzo
    Suzuki Bandit 600S (Green with added shit bits)
    Yamaha SR250 Delusion (It's "Special")
    I ride way too fast to worry about cholestorol.
    Lozzo, Apr 6, 2007
  2. frag
    frag Guest
    ginge banged the rocks together and they said :
    Yep, the C2 used a 180, E1 a 190 because it looked fatter. I know Bear
    changed his back to a 180 and said it made the bike better, so I did,
    and it did.
    Where does it stop?
    frag, Apr 6, 2007
  3. frag
    ginge Guest
    Anywhere you decide to pull the brakes. :)
    ginge, Apr 6, 2007
  4. frag
    frag Guest
    Lozzo banged the rocks together and they said :
    *ding*
    Being the point.
    frag, Apr 6, 2007
  5. frag
    Molly Guest
    I think it's my typo. I did some time ago and I think they shgould both be
    C1/C2
    Molly, Apr 6, 2007
  6. Remember to check the head race bearings. I discovered mine where pitted
    on one of the Sedan runs. I was f*cking horrible on turn in to bends. I
    never thought it would have made such a difference.
    eric the brave, Apr 6, 2007
  7. ZX9c1-c2 had 5.5" rims E1+ has 6" rims.
  8. frag
    frag Guest
    eric the brave banged the rocks together and they said :
    Its just been given an MOT (yes, I know it can mean sod all from the
    wrong place), so in theory they should be fine. I will check em :)
    I do know that I need to sort out the throttle cables now.
    I've fitted risers and as per instructions I've re-routed the cables
    between the tank and frame.
    On full right lock the cables are pulled almost tight, and sometimes
    one catches beneath the ignition lock and is pulled more than tight and
    the revs blip - not good.
    A temporary fix is just a cable tie, but I think the cables are
    moving/bending too much due to lack of length which'll cause more wear
    and make them snap soon.
    Anyone know where I can get new throttle cables made up to suit? Need
    to be approx 1.5" longer than standard.
    frag, Apr 6, 2007
  9. frag
    You don't need to shim the rear, it's got ride height adjustment.
    Andy Bonwick, Apr 7, 2007
  10. frag
    ginge Guest
    Isn't it ride height adjustment by adding shims to the top suspension
    mount, like the 10R?
    ginge, Apr 7, 2007
  11. frag
    It's got screw and locknut adjustment on the E1.
  12. frag
    frag Guest
    Andy Bonwick banged the rocks together and they said :
    frag, Apr 8, 2007
  13. frag
    What mileage did it have on it? Mine were done at round 28K.
    CT, Apr 10, 2007
