ZX9r oil
Discussion in 'UK Motorcycles' started by apoljuga, Mar 14, 2007.
  1. apoljuga
    apoljuga Guest
    Hi,
    please can you recommend oil for the ZX9R C2. I'm thinking about
    Silkolene Comp 4 10W40 or MOTUL 5100 10W40. Kawasaki in service manual
    recommend 10W40 or 10W50 oil. Is semi synthetic good enough for normal
    road use. Also found on the google that Silkolene maybe improves
    gearbox performances.
    Thanks!
    Cheers,
    Alen
  2. apoljuga
    Thick gloopy stuff, often sort of dark in colour, comes out of a
    plastic container.
    Is there something wrong with your gearbox performance?
    _______
    Ace, Mar 14, 2007
  3. apoljuga
    apoljuga Guest
    Ace je napisao/la:
    Hmmm didn't know that. Now I know what to look. Thanks.
    ZX9 are prone to problems with false neutrals. Found that on '99
    Kawasaki recalled bikes to oil change (Silkolene) to decrease this
    problems. People said it helps.
    I just bought bike and on first 100 miles found 1 false neutral. I'm
    not worried but if I can improve this with some oil why not.
  4. apoljuga
    Switters Guest
    Blimey, I get it on mine, and figured it was just mine, or me being slack
    when changing gear. Didn't realise it was endemic.
    Oh, I use fully synth (not sure of the make), but clearly it doesn't help.
    Switters, Mar 14, 2007
  5. apoljuga
    Eddie Guest
    They are? No more so than any other bike, IME.
    Work on your gear-changing technique.
    Because anything that "allegedly" improves the performance of your
    gearbox might decrease the performance of something else... your clutch,
    perhaps.
    Eddie, Mar 14, 2007
  6. apoljuga
    says...
    I ran my ZX-9R C2 on Motul 5100 semi-synth and never found a false
    neutral. I just did an oil change for a friend and put the same in her
    '98 C1 model. Hein Gericke are still doing their £24-50 oil and filters
    deal, I was lucky and managed to find an air filter in stock for her
    bike. The air filter alone is about £14, which makes it a very cheap way
    of doing things.
    Lozzo, Mar 14, 2007
  7. apoljuga
    apoljuga Guest
    Lozzo says:
    Thanks I think that I'm going also with Motul 5100. I have offer for
    oil+filter for 29£ but I will go to see in Hein Gericke.
    Cheers,
    Alen
  8. apoljuga
    says...
    Hein Gericke supply 5 litres of Motul 5100 with oil filter and air
    filter for £24-50, that's why I always buy my oil there for the Bindit
    and those bikes I look after. Unfortunately I can't do this with the
    Triumph because it takes some weird viscosity oil and original filters
    aren't expensive for that bike.
    Lozzo, Mar 14, 2007
  9. apoljuga
    apoljuga Guest
    Lozzo says
    Even air filter. Is this offer available in every Heine Gericke shop?
    My in Nottingham is quite small.
    Alen
  10. apoljuga
    says...
    All HG shops do the same deals, but the filters are only available in
    the deal if they are in stock. My local shop will let you take the oil
    and oil filter for a ZX-9R and if they don't have an air filter they'll
    let me have a Bandit one instead.
    Luckily, I know for a fact that they have an air filter in stock for a
    ZX-9R, so I might pop down and blag it for Elly as my Bandit needs an
    oil change soon and I already have an air filter in stock for that bike.
    Lozzo, Mar 14, 2007
  11. apoljuga
    apoljuga Guest
    Lozzo je napisao/la:
    I will pop down to my HG shop to see do they have it on the stock.
    Thanks
    Cheers
    Alen
  12. apoljuga
    Beav Guest
    I use Catrol R4 in the Zed thou (same engineish) and the gearchange is as
    smooth as silk, plus of course the engine runs wonderfully. Fully synthetic
    it is, or supposed to be. It's never needed a top up between oil changes
    either and the bike seems to like it.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 14, 2007
  13. apoljuga
    Beav Guest
    If the oil has friction inhibitors, it'll help the box but make the clutch
    slip if it's a wet clutch.
    Not a guess.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 15, 2007
  14. apoljuga
    A Bandit 12, for example, run on synthetic oil.
    Pip, Mar 15, 2007
  15. apoljuga
    Eddie Guest
    .... or any 1000cc V-twin from Aprilia.
    Eddie, Mar 15, 2007
  16. apoljuga
    Beav Guest
    Yeah, but has it got friction inhibitors too? I run the Zed on fully
    synthetic, bit it's for wet clutch bikes. There's usually a number on the
    tin, but I can't remember what it is. Anyway, if the number is there, it
    shouldn't be used with wet clutch bikes. Not that that's much help, mind,
    but the "usage instructions" give enough info that getting the right stuff
    isn't hard.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 15, 2007
