ZZR250 1st gear problem
Discussion in 'Australian Motorcycles' started by Skuz, Jan 13, 2004.
  1. Skuz
    Skuz Guest
    A friend has managed to drop my ZZR250 by getting off and letting go without
    putting the stand out first.
    The bike came down on the left side and took her down with it. She is okay
    but the bike is not as lucky.
    Cosmeticly there are a few minor scratches on the mirror, bar end and
    exhaust. The real problem is the bike won't shift into 1st anymore. I can
    shift up to second (rolling to get passed the posi-neutral) and beyond but
    shifting down the lever doesn't seem to click down but still changes down
    all the way to neutral.
    Anyone have any ideas on what's damaged in the transmission based on the
    symptoms?
    I'm thinking the shift arms that operate the drum may be bent, which would
    mean removing the clutch or the drum is damaged which would involve
    splitting the case. I'd attempt the clutch removal myself but not the
    splitting the case.
    Skuz
    '91 ZZR250
    Skuz, Jan 13, 2004
  2. Actually, splitting the case on a ZZR engine is not that big of a job.
    Alternatively, if it's really stuffed, I know someone with a ZZR250 engine
    they want to flog off.
    But, now that my spamming is over, are you sure it's not just the shift
    lever being bent? That's the most likely cause.
    If it's not that, then it's possible that you've done something nasty to the
    selector shaft, or something like that, and you'll be needing to take the
    clutch cover and clutch off (be carefuly, the retaining nut on the clutch
    basket _will_ require a rattle gun to get it off. Don't use a torque wrench,
    you'll break the basket).
    Once you've got the clutch out of the way, you'll be able to remove the
    selector shaft then and see what the problem is.
    James Mayfield, Jan 13, 2004
  3. Skuz
    Fwoar Guest
    Does the gearbox go through all gears?
    Does it feel like the lever doesn't return as normal
    I suspect that the detent Spring may be worn & fell off
    Daron
    Fwoar, Jan 13, 2004
  4. Skuz
    Big Fella Guest
    Have a look at the rod that connects the foot gear shifter back to the
    engine body. It's got thread adjustments both ends. This could have
    somehow got bent or adjusted so far down that there physically is not enough
    travel to select 1st any more. On my old ZZR250 this rattled out of
    adjustment whilst I was ridding, giving the same symptoms you describe.
    Cheers,
    Paul
    Big Fella, Jan 13, 2004
  5. An expensive way to learn that yours shouldn't be the bike people have their
    first-ever riding experience on.
    More information... have you tried shifting further up? Into 2nd, 3rd, 4th
    etc, then back down again?
    If you can shift up, but not down all through the box, then the problem's
    likely to be on the outside (bent gearshift linkage, as suggested, or the
    pedal...), but, and I doubt this is too likely, if you can shift down from
    4th to 3rd, from 3rd to 2nd, and from 2nd to neutral, but not to first, then
    the problem might be internal.
    Again, the latter is Loch Ness Monster-sighting unlikely. Bikes have landed
    on their left sides from 10 feet up in the air and not damaged their
    gearboxes. Yours should be fine.
    Intact Kneeslider, Jan 13, 2004
  6. Skuz
    sharkey Guest
    Is the lever not just bent and interfering with something else?
    That's the first thing to check. Often the click down into first
    needs the lever to move a bit further than the others, I know if
    I bend the gearlever on the XLV it fouls the bashplate and won't
    shift into 1st ...
    Maybe, but there's generally a few other bits first, the gearshift
    shaft isn't attached directly to the shift drum, it'll go to
    another widget first. It's more likely that that widget is bent.
    BT will know, he's an expert at throwing away those engines :)
    -----sharks
    sharkey, Jan 13, 2004
  7. Skuz
    sanbar Guest
    Can't you just take it to the mechanic and present her with the bill? It
    would be easier to do if you're sleeping with her ...
    - sanbar
    sanbar, Jan 14, 2004
  8. Skuz
    Skuz Guest
    Thanks All. Got it sorted.
    The lever was fouling on the the part that the side stand spring hooks on
    to. I can't believe I didn't see it straight off.
    It was as Sharkey suggested, first gear needs that little bit more travel as
    it changed up and down through the other gears without a problem.
    Hehe. The friend is my wife's sister who is having a hard time affording to
    get her own bike back on the road, hence practising for her Ps on my bike.
    Skuz
    '91 ZZR250
    Skuz, Jan 14, 2004
  9. Skuz
    sharkey Guest
    good news!
    -----sharks
    sharkey, Jan 14, 2004
  10. Skuz
    Bastardo! >:-|
    But yes, I think it's worth taking a good look at the external shifter
    linkage first. Maybe even remove it and see if you can engage first
    using a pair of pliers?
    BT Humble, Jan 14, 2004
  11. Teachers pet!!
    Hammo
    Wanna split some TT cases with me?
    Hamish Alker-Jones, Jan 14, 2004
  12. Skuz
    sharkey Guest
    Yeah, sure. What's wrong with it?
    -----sharks
    sharkey, Jan 15, 2004
  13. Skuz
    Nev.. Guest
    I had a ZZ-R600 that did that once...
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Jan 15, 2004
  14. Gearbox, 3rd is naughty.
    Hammo
    Hamish Alker-Jones, Jan 15, 2004
  15. But I don't drink TT...
    Postman Pat
    Pat Heslewood, Jan 15, 2004
  16. Skuz
    Johnnie5 Guest
    mates DR250 fell over ;) and the gearlever contacted a rock and snapped off
    a lug in the gearbox and wouldn't change up or down , stuck in neutral
    this was down Heathcote way , you would know the place IK where all the
    dirtbikes
    hangout , fortunately this happened on a major trail,and the 4x4 went down
    and got it out
    also fortunate it was still in warranty , but took a while for parts to
    arrive
    Johnnie5, Jan 15, 2004
  17. I have a case of VD, interested?
    Hammo
  18. Skuz
    Gary Woodman Guest
    There's a warranty against falling over? Cool!
    Gary
    Gary Woodman, Jan 16, 2004
