ZZR600
Discussion in 'UK Motorcycles' started by cheryl, Jun 27, 2004.
  1. cheryl
    cheryl Guest
    Hi Guys and Gals
    I'm looking at a ZZR600, 1990 with 6 months MOT and Tax, cracked fairing and
    needs a new indicator (so dropped), 20k miles.
    He's after an offer around £500, should I snap his hand off or wander away
    muttering?
    Ta for any advice. Hopefully I'm off to haave a look at it on Monday.
  2. cheryl
    Verdigris Guest
    I'd say that the key thing is the damage. Is the fairing repairable? Is
    anything important bent? (Frame, headstock, forks, bars.)
    Verdigris, Jun 27, 2004
  3. cheryl
    Nidge Guest
    Yep what the man sez.
    IF the cracked fairing and indicator are the only problems its a steal and
    you should take a section of his arm along with the hand. IF.
    At that price you can tape up the crack with gaffa tape and still sell it
    for half as much again....... If its as stated.
    Your real risk is has the frame twisted when the fairing and indicator were
    taken out? If you're not up to checking that yourself (and for sure if its
    not major I reckon few folk would spot a twist) the history of when the drop
    happened and subsequent mot's *might* give an indication at least whether
    the testers are happy. If its not been tested since the drop maybe you can
    make either a frame check or a new mot a condition of sale?
    I've not owned one but IRC zzr600s original back shock's are said to be dead
    by 10k miles so that's an obvious check to emphasise as part of your routine
    check everything overview.
    Nidge
    ZX6R J2 Stunning in zit yellow. KX 125 MX 'I'm snot green -fly ME'. A few
    bits of CB500S in Norwegian Parrot blue. BOTAFOT#63
    'Just because I don't care doesn't mean I don't understand'.
    Homer (Simpson).
    Nidge, Jun 27, 2004
  4. cheryl
    Why would it bother them? AFAIR its not a testable item per se.
    If the bike passes on wheel alignment and assessment of corrosion then
    the frame can look like what it wants to.
    sweller, Jun 30, 2004
